Driver door sagging!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Feb 2, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    The driver door has started sagging really bad...so bad that the door is rubbing agianst the fender,and paint is starting to chip. Has anyone done this fix,and what did it consist of? Thanks in advance!
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>Just some Negitive Space..</a>
  2. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    quit using it to jump into your truck..lol, jk[​IMG]
    [​IMG]Mash Out![​IMG]
    82 Blazer 1 Ton "Big Nasty"
    78 Jimmy 3/4 Ton
    <font color=red>"Red Dawg" </font color=red>
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    They just get metal fatigue after awhile, on my 74 my Bro( the cheese it together guy) took two 2X4's used one as a lever and the other as the fulcrum and just lifted it back up and bent it back into shape, but it could be just as simple as adjusting the hinges since you have an 84'
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    The hinges use small brass bushings that seem to wear out quickly. I'd replace the bushings and hinge pins and then adjust the door so it closes nicely again. I would not wait to do this project, as you can see it can damage fender and door edges but it can cause the striker area to fatigue and crack as the door needs to be slammed harder and harder to close.
    I've founmd replacement bushings and hinge parts at most parts stores. The last set I bought it cost me under $20 for both doors.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    I just replaced the bushings on my driver's door today, it use to sag a lot but now it's fine. It was a piece of cake doing the work after I got the right bushings, First I got silver looking bushings from Help! that said GM on em but they didn't fit, then I got the brass ones and they fit.
    80' GMC Jimmy 4x4, 350-TH350-NP205
  6. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    when I put on my new door's.. we changed out the hinges as well- they were not sagging, BUT you can almost guarantee that after the new doors were on, they would... I'd have to say it was a PIA... I personally thought that swapping the glass in the doors was easier- even swapping the vent windows.... dont try to do it ourself, that door gets quite heavy very quickly..
    Brandy
    LOVING the new Duramax!!!
  7. dyeager535
    26,979
    If it just started sagging, and you haven't adjusted it, chances are a new hinge and bushing will completely solve the problem, without adjusting the door. At least thats easy enough to do, remove the bolts holding the hinge to the door (tougher if its PW/PDL) then cut the pins and replace them. THAT is easy.
    If you actually have to realign the door, it will take some time. However, the time spent fixing the hinges even the long way, is still less than fixing a striker bolt that has ripped the door frame, or hinge reinforcing plates that have pulled through the door.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
