Driver drop np205
Discussion in 'The Garage' started by Goose, Mar 6, 2007.
  1. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    A while back a bought a divorced np205 sight unseen planning on using it in a few years.
    Last night I was looking it over and it is a driver side drop. :confused:
    My question is this useful for maybe a straight axle swap or just for Ford guys??
  2. greythorn3
    greythorn3 1/2 ton status
    Oct 14, 2002
    174
    Anchorage alaska
    Ha
    I run a ford one in my chevy.. just chnage the input shaft to 32 spline.. works great if your running a ford front axle. u also have to retap the hole in th efornt of the case for your adapter
    ray
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    ah he said its divorced not married tcase. but the rest of your info for use with ford axle is good.
    all 205 divorced tcases are 32 spline outputs. good for updating the 10 or 30 spline front outputs in others.
  4. greythorn3
    Oct 14, 2002
    174
    Anchorage alaska
    Sorry didnt notic that! ha, but that information you have is good.... didnt know that all divorged were 32 spline outputs.. i buy ford 205s cheap and put there outputs on my chevys. since all fords are 32 spline outputs, and married are 31 spline inputs..
    ray
  5. Goose
    1,127
    Thanks for the info guys.
    So mostly useful for swapping outputs then?
    Would someone doing a straight axle swap into a newer chevy find it useful because of the passenger side clutch cylinder setup??
