driver side headlight/tail lights won't work...Help!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Mar 7, 2002.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    driver side headlight/tail lights won\'t work...Help!!!!
    Been a while since I've posted but I need some spark chasers to help me out on this. I thought I had a bad bulb at first...well...I've tested new bulbs...same problem...Need some good advice as to what to do. my turn signals work, parking lights work and brake lights work....it's only the headlamp and tail light that do now work on the drivers side. no other electrical probs. what could it be?
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Re: driver side headlight/tail lights won\'t work...Help!!!!
    I just had a problem on my tail-light, the brake/turn signal bulb wouldn't light up and it turned out to be a broken wire. trace the headlight and tail-light wires into the harnesses and see if there is a broken wire somewhere. Other than something simple like a fuse issue, thats all I've got.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you can also tryand clean the connections, sometimes you get corrosion there.
    ARQ.
  4. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Check the grounds?
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is strange
    the front harness and rear harness are usually seperate
    a one side is dead doesnt make sense as 1 problem
    <a target="_blank" href=http://community.webshots.com/album/27265454zmsiZjCZMj>http://community.webshots.com/album/27265454zmsiZjCZMj</a>
