driver side reduced steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madmike, Apr 9, 2002.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I'm looking for comments/opinions on this. I have a 1980 1/2t truck with 10 bolt front and 12 bolt rear, and I installed a 6" BDS spring lift on it last fall. The truck previously had a 4" lift on it, so I retained the proper (for 4" lift, but same p/n for 6") steering arm on the knuckle. After the lift was installed, I had it realigned. With the 4" lift, my turning radius was equal on left and right hand turns. Now, with 6" of lift, I cannot make left turns as well as right. I can't stand it, and in heavy traffic (my truck's a daily driver also), it can be dangerous because sometimes I can't make a turn that I knew I could previously. My questions are: should I consider the addition of a dropped drag link or different pitman arm?
    In the next couple of months I plan on installing my Dana 60/14bff combo. I have read and understand that crossover steering will easily correct that problem, but at the expense of a little more bumpsteer. I use my truck as a daily driver mainly, but I really want to get into more serious fourwheeling with it. I've also read a lot of posts on Death Wobble, which has me mildly concerned, because with the luck I have, I'll probably swap all this 1/2t crap out and get 1 ton DW, which I can't have on something I use every day. Is the crossover steering gonna be worth the expense and effort? I have 4:10 gears and plan on running 36" radial super swampers, if that helps. And no, my axle combo ain't for sale!
  2. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    Sounds like you have a 4" raised steering arm, that’s what you want. But now you should add a 2" drop pitman arm. While replacing the Pitman arm you should also re center the steering
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    adjust your draglink length until it steers equally both directions
