Driver Side Wing Window Needed (And instructions???)
Discussion in 'Parts & Trucks Wanted' started by rigdonhome, Jul 1, 2003.
  1. rigdonhome
    rigdonhome 1/2 ton status
    May 11, 2003
    252
    HoosierLand
    /forums/images/graemlins/1zhelp.gif I had to bust into my own truck today and thought it would be easiest to replace the wing window... Holy Hell, how do you get it out??? I removed a nut and a giant spring from inside the door, and it still won't come out!!! /forums/images/graemlins/1zhelp.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    like 3 screws around outside edge of door, i bolt right under the lock/lever and 1 half way down the door. Sorry i don't have one tho, i only have a spare pass side one.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    remove rear track, one screw under door panel towards bottom back corner and one on side of door jamb side up around exterior door handle height, remove them and slide the rear steel track down out of way, the glass weatherstripping channel slides in it,
    slide door glass towards back of door and remove the three phillips indentated screws along top of doro front side triangle area, and remove screw under doro panel that holds bottom part of ent assembly, pull assembly back and down at the top and then start twisting the entire assembly and guide it out of door through the notch at the vent assembly post, i have a good clean vent assembly if you need one, PM me or something
    the spring and nut is for the vent glass to pivot in the vent assembly frame, its easier to swap entire assembly than just the glass, the glass pivots on top part with a rivet that has to be drilled out
  4. DUKSRULE
    DUKSRULE 1/2 ton status
    Nov 25, 2001
    303
    Va Beach Va
    I have one from an 86 truck. Let me know if you are intersted.
    Rob
  5. rigdonhome
    May 11, 2003
    252
    HoosierLand
    Rob
    I have one lined up from another CK5 guy, but if for some reason that doesn't work out I'll let you know. Thanks!
    Cheers,
    Scott
  6. mirage
    mirage Registered Member
    Apr 1, 2002
    37
    Mesa, Az
    ARG!!!!! Had my truck broken into while at church today! Fortunately all they took was some $12 locks, left the $200 tools, ha! They were covered with a sheet :-).
    Anyway, I'm in need of the driver vent window, still have yours?
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have one if no one else can help you first, PM me if so
    thanks
  8. rigdonhome
    May 11, 2003
    252
    HoosierLand
    Got a good window from R72K5 for cheap! Thanks Man!
    Cheers,
    Scott
