Driver vs Passenger Drop NP241 Question
Discussion in 'The Garage' started by DPI, Mar 6, 2007.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Are the adapters for the driver vs passenger drop 241s the same? I mean, can I use a passenger drop 241 adapter with a drivers drop case?
    This is the 700R4 variety.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, no difference in the gm adapters
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Great, thanks for the info~!
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I thought there was a difference on the adapters between which drop was being used. :confused:
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope, the pattern is the same and the clocking of the pattern is the same. the only way to get a different clocking of the 6 bolt round pattern is to change the make of the tcase; IE ford or dodge. the mounts are only different depending on if its the tall or the short adapter.
