Driver's Door Alighnment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Huey, Jul 6, 2003.
  1. Huey
    Huey Registered Member
    Jul 4, 2001
    5
    Driver\'s Door Alighnment
    How does one get to the top door hinge assembly bolt. THe manual says to remove the forward fender bolts, then use tool J-22585, whatever the heck that is, and loosen the hinge bolt. I tried this but could not budge the fender. There definetely is a bolt that threads from inside the body area, but how to get at it. Where does one get the special tool? I need to move the hinge forward to better align the door. Any suggestions?
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Re: Driver\'s Door Alighnment
    Pull the inside wire grommet out and carefully use a 9/16" socket to loosen/remove that last pesky bolt. I usually goop the socket with permatex to avoid dropping the bolt. The passenger side is easier as you can pull the glovebox out of the way. The drivers side is a little more difficult as you need to pull the A/C vent etc to make it easier or you can just be patient and leave that stuff in there.
    Mike
  3. Huey
    Jul 4, 2001
    5
    prjt_blzr , Are you saying that the fender bolts do not have to be removed? If I understand you correctly, I can access the bolt through the interior of the cab? It is the drivers side I must align, so if I remove the AC duct, I will find a hole directly across from the hinge bolt?
  4. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    BEHIND THE DASH ABOVE THE E-BRAKE IS A GROMMET WITH TWO WIRES, PULL THIS OUT AND FEEL IN BEHIND AND YOU WILL FIND THE BOLT YOU NEED TO LOOSEN /forums/images/graemlins/thumb.gif
    [image]http://coloradok5.com/photos/showphoto.php?photo=6654&password=&sort=7&thecat=500[/image]
  5. COLLISION
    May 15, 2002
    175
    THERE WE GO. /forums/images/graemlins/thumb.gif
  6. Huey
    Jul 4, 2001
    5
    Gents, thank you very much. Would not have figured that one out.
  7. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    First of all, why do you need to adjust the door? Are you putting a new door on or is it not closing properly? If it's not closing properly then are you able to wiggle it up and down? If this is the prolem then you need to replace the bushings inside the hinge to repair it correctly.
