Drivers side tail light?
Discussion in 'The Garage' started by cegusman, Oct 8, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    When I turn on my lights my drivers side tail light stay lit up like I am on the brakes. If I hit the brake the light does nothing. With the lights off and I hit the brakes the brake lights work fine. What would cause this.
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    check the lightbulb.
    if one of the elements is broke & shorted to the other element.
  3. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    Did you replace that bulb and then notice this or did it just start happening out of the blue?
    I would say replace the bulb if you have not. Or if you did, make sure it isn't in backwards. The tabs on the bulbs are offset for this reason.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    It just happened out of the blue. I will change the bulbs and see what happens.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Changed the bulb and it fixxed it.
    Thanks /forums/images/graemlins/thumb.gif
