Drivers side window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Dec 3, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    My drivers side window switch (Elec) has quit working, also the switch for the pass side (On the drivers door) isn't working either, what do I check? I remember reading that there are connections to the left of the fuse panel? where exactly are these connections?
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Pull the panel off the door and check the backside of the switch itself. On my Jimmy the wires had corroded and a couple actually broke off. I used some bare crimp on bullet connectors and replaced the bad wires that way. I just made sure to wrap each connector with electrical tape so they didn't short on each other.
    I've also had the wires going to the window motor corrode and break off...an insulated female spade connector plugs right in to the motor.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. dyeager535
    26,979
    BTW, switches can be taken apart (carefully) and fixed. There are just small contacts that get corroded in there. I can't believe I hadn't taken one apart before, its so simple to do, and simple inside.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Save yourself the headache, you don't have to remove the door panels. The switches pop out. Clean them out, make sure your connection is tight and test them. I would also jump the terminals just to be sure it is the switches and not something else.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  5. bking
    Jan 4, 2001
    176
    Agggggggggg, just smashed the switch to bits 'popping' it out
  6. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    Look on the bright side, you can replace the switches at your local Autozone style chain parts store in the "Help" section for like 10-15 bucks.
  7. bking
    Jan 4, 2001
    176
    hahaha, I actually smashed the surround, the lip around the switch, looks BAD....It's -4F here at the min, guess it was a bit 'brittle'
  8. bking
    Jan 4, 2001
    176
    okok, on the back of the switch there is a blue screw, with 'twist off' written on it, what is this? does this seperate the connecter from the switch or what?
  9. SKI-'84K5
    SKI-'84K5 1/2 ton status
    Oct 11, 2001
    175
    Imlay City, MI
    yes twist it off and take off the cover plate, clean your terminals and slide it back together and see if it works, you can also use some wire and bypass the switch to see if it is the switch or wiring that is bad
