driveshaft and crossmember don't like each other
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Oct 9, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    driveshaft and crossmember don\'t like each other
    I have a 4" lift, and my t-case is dropped an inch. The cv is hitting the crossmember, not constantly, but every now and then when the k5 gets in a certain position offroad. I'm worried because that driveshaft doesn't look very strong to start with and every hit is weakening it. I would like some opinions on how to solve this stupid problem. And why have I never heard of anyone else having this problem? Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Re: driveshaft and crossmember don\'t like each other
    Energy Suspension transmission mounts. I looked at that area on mine too and it was close with stock mounts. I upgraded to the ES mounts and it has cleared up some drivetrain noise and cut down on the flexing that the stock mounts show signs of.
  3. Grim-Reaper
    7,385
    Atlanta
    Not sure where to find this but there is a 1 inch spacer plate that bolts inbetween the case and the CV that may correct your problem. It may cause you a second problem that you need to be aware of in that it may make the drive shaft to long and you may have to shorten the driveshaft.
    Another thing is did you correct the pinion angle when you lifted the truck? The pinion has to be in line and usualy reqires a 2.5 deg shim at the springs. this would raise the pinion and driveshaft and if it's missing may be the small amount that will get the shaft to clear.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I had the same problems when I put a 6 inch lift on my 86 Silverado. I simply had a friend make 1 inch spacers out of some metal stock. My truck had a NP208 and it has two bolts that attach the tranny mount to the cross member. I put the spacers under the tranny mount and then two other spacers between the frame and the cross member on both sides. Or you could stack washers but I wouldn't recommend it. I hope this helps. It will make more sense if you just poke your head under your Blazer and you will see what needs to be done.
    Dazed and Confused in a 74 Blazer
    Zeppelin
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I am not positive, but I don't think my k5 has that shim. I'll have to go to 4x4 shop where it got lifted and bitch so they do it for free. If that doesn't work I'll look into the ES mounts and the spacer. Thanks guys.
    Brian
  6. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    I am having the same problems in my '87 w/ 4" lift and 36" Swampers. Usually it seems to hit when I am going up inclines. I was guessing that it was a failing tranny mount. Keep me informed if you are able to solve your problem.
