Driveshaft and lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Mar 18, 2002.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    With 6" lift will I run into drive shaft trouble? I now have 4" but running 35's it hits when it flexes. (I have the swaybar out). I already cut the fenders, so that option is gone. What are my options of getting out of driveshaft trouble with a 6" lift?
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    You might be ok(slim chance). The rear should be fine, but the front will want to bind on you some. Some things you can do is obvisiously use a space on the front of your tcase or get your shaft lengthened. The "ears" on your front shaft around the upper u-joint will need to be grinded down some to take out the bind. Hope this helps somewhat.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just cut your fenders more or get a body lift.
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Sammy,
    You could try the ORD 1" Body lift... depending on how seriously you're rubbing, a minor body lift could be all you need to do. That would save you from buying new springs, or doing driveshaft changes.....
    Just another idea.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Go for a bodylift. I just installed a 3" bodylift on my 79. It was easy and gave me alot more clearance.
  6. newbe73
    newbe73 Registered Member
    Mar 14, 2002
    58
    SD
    i have 4 inc now and my driveshaft is half whay out so if it is the stock 1 it will never work ou will need a longer one but ya if you really want that much clearence outer wise i would do body
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Are you using a shackle flip, springs, or blocks? I have a shackle flip and blocks totaling 5 1/2'' of lift using the stock driveshaft. The shackle flip corrected the pinion angle and the slip yoke was only pulled out of the transfer case 3/8'' more than stock and it doesnt vibrate. The 35''s still rub pretty badly with 6'' unless you take off a little sheet metal (i removed 220 square inches). I am still using the stock front driveshaft too and it doesnt seem to bind or limit my flex. Then again if you already have a 4'' installed, dollar for dollar you are far better off with the body lift and/or more trimming.
