Driveshaft angle causing vibration at speed?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Oct 30, 2002.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I've been battling a vibration issue for a while now, and think maybe I've got it tracked down. I have an '84 blazer, 2 1/2" ORD shackle flip, 14 B FF, running 33" tires.
    The vib used to happen during acceleration, deceleration, and just about all the time. Recently, I swapped out the U-bolts and spring plates for 1 ton (I was running 1 ton u-bolts on 1/2 ton plates) and I lowered the T-case using the 1" spacers.
    The vibrations have almost gone away now. It is smooth during acceleration and deceleration, but I get a pretty bad whirling around 55mph and above. When I say 'whirling', I mean it is a vibration that comes and goes in time; Almost like a bearing would feel.
    If I'm doing 60mph, and I shift into neutral, the vib is still present but it becomes constant instead of cycling. When I shift back into drive, it starts the cycling again.
    Looking at my drive shaft angles, the drive shaft is almost straight in line with the pinion and has a pretty good angle up at the T-case. Would this cause what I am describing? and if so, do I need to shim the rear to bring the pinion down some?
    Thanks for any advice,
    Thomas.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Do you have a CV on the rear shaft?
    If not then you got the wrong setup.
    When you have a CV you line up the drive shaft with the pinion and point it to the CV, but if you don't have it, you should have the pinion parallel (within 2 degrees) with the output on your T-case.
    That would definitely make a Vibration the way you have it. /forums/images/graemlins/smile.gif
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    No, I have the stock drive shaft. So do all 14B FF axles point the pinion up to the T-case, or were my perches moved?
    I was going to bring the drive shaft into the shop and have them weld a 1350 yoke on and balance it ... thinking that maybe it's out of balance. But if the pinion pointing upwards is causing my problem, can I shim the rear to bring it down some?
    Thanks for the info,
    Thomas.
  4. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Do you have a slip yoke on the drive shaft? If so check the splines to make sure they are not crap.
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    There is a slip yoke into the NP208 t-case, but not one in the middle of the driveshaft.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes you SHOULD shim the rear to bring it down. It might be easier than turning the pads.
    Also check the slip yoke in the T-Case, grab it and try shaking it up and down if there is movement then you have a problem if not just turn down your pinion.
    Yes the 14bolts usually are on long trucks, longer than the K5 at least and they used a 2 piece drive shaft with a bearing support in the middle so the pinion would be pointing up.
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Ok, great! Thanks for the info.
    Do you know if anyone sells a shim that will also provide 1" of lift? Like the ORD 1" zero rate add a leafs with an angled cut?
    Might as well lift the rear another 1" if I'm going to be putting in shims anyway ....
    Thanks again,
    Thomas.
  8. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    you need a c/v joint at the t-case - what your feeling is called gear rattle- Jess
  9. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    I thought about that too, but couldn't find a C/V setup for the NP208 that wouldn't break my bank.
    Do you offer a C/V setup that'll work with the NP208 and my stock shaft? If so, I would love to know the price of it?
    Thomas.
  10. drivelineman
    Aug 23, 2000
    707
    449.00- its all one ton- Jess
  11. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Does that price include the whole shaft, from t-case to pinion?
    If it does, would just your slip yoke with the CV mate to my stock shaft with a conversion joint?
    Thomas.
  12. drivelineman
    Aug 23, 2000
    707
    its complete unless you want the 1 ton at the diff its 56.00 for that yoke-Jess
  13. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    I'm only running 33" tires right now, and eventually plan to go to 35" with a whole lot of fender cutting (maybe add the 1" zero rates), so I don't really need the complete 1 Ton setup.
    Sounds like your slip yoke with the C/V joint is perfect for me. I'll be giving you a call in the morning.
    Thanks Jess,
    Thomas.
  14. drivelineman
    Aug 23, 2000
    707
    its got a one year waranty too-Jess
  15. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Alright, well I had my driveshaft lengthened about 1 1/2", 1350 yoke welded on, all new U-joints, and it was balanced.
    I still have the vibration /forums/images/graemlins/mad.gif I took the Blazer down to the drive train shop, and they measured the angles at 6' and 7'. He said those are perfect, and my vib isn't due to a driveline angle issue. He said the most likely cause is a blown out NP208 output bushing, and I should try replacing it. He said the driveshaft being too short could have put too much stress on it and ruined it.
    Does this sound reasonable? Is there anything else I should do to my t-case when I repalced the bushing and seal?
    This vib is really starting to drive me nuts. It's like a mission now, I won't quit until it's smooth! /forums/images/graemlins/wink.gif
    Thomas.
  16. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Try this guy:
    Custom leaf spring shims
    I haven't bought from him, but I'm planning to. I need to measure what angle i need first.
    -- Mike
  17. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks for the link. Looks like he has a pretty good setup going on. But it seems my angles are ok (6' and 7'), so I really don't need to shim the rear yet. Once I get this vib issue resolved, I am going to lift the t-case back up and then I'll most likely need the shims.
    Thanks,
    Thomas.
  18. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Which was 6 and which was 7? That is a static measurement. While driving (especially accelerating and decelerating, or maintaining higher speeds), the pinion will rotate up and down. Up while acclerating or mainting high speeds, and down when decelerating. A 1 degree difference can become a 3-4 degree difference pretty quick. I don't know if you have covered this, but making sure the driveshaft is perfectly balanced (may want to take it to a different shop to balance just to see), and the tires and brakes are all set. I have even heard of a slightly bent axle shaft causing vibration that was hard to diagnose.
