driveshaft angle questions before I weld the perches
Discussion in 'The Garage' started by josh86k10, Dec 20, 2006.
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I've got everything mocked up, with the truck's weight on the springs. Right now I've got 6 deg down on the t-case (fairly stationary)... so I put 6 deg "up" on the axle pinion (not welded yet). That put's my driveshaft at 17 deg down slope. And if I know what I'm doing, that gives an 11 deg operation angle on each of the joints, right? Maybe 12 deg depending on how good my eyes are under a truck on my back. For some reason it looks kind of steep. Should I tack her in place or tilt the pinion up some more. Still running S44 joints (a bastard S44/1350 at the axle). FWIW this is a Short bed K10 with roughly 7" of lift (shackle flip, add-a-leaf, and zero-rate...axle moved back 1.5"). HELP!!!
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would move the axle down 2 deg to account for wrap when under load. With the pinion a couple degrees lower when under load it will actually be right on with the Tcase. If you put them the same at rest then under load the pinion will be higher in slope than the Tcase and could cause vibrations.
    Ira
  3. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    Well, my biggest concern is the 11-12 degree operating angle. I don't want to make that any steeper than it already is. Is 11-12 degrees okay, or will it eat u-joints?
  4. sandawgk5
    Oct 28, 2003
    6,881
    Mine is at 14 but other than that I dont have an answer.:o
    Ira
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    anytime you increase the operating angle of a u joint it won't last as long. Just replace them once every 18 months or so. I say weld it where you have it. You won't be having much axle wrap at cruising speeds.
  6. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
  7. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    I appreciate it ya'll. For better or worse, She's welded up and that's where she's at. I'll let ya'll know how it works out.
  8. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    I was looking through my old posts and realized that I never let everyone know how it turned out. Zero vibrations.... other than the ones from the TSL's, but actually zero vibrations with my street tires on. Just figured I'd post up a conclusion in case this pops up in someone's search some day.
  9. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Good deal! :waytogo:
