driveshaft angles...8in lift
Discussion in 'The Garage' started by kevin_saun, Feb 23, 2004.
  1. kevin_saun
    kevin_saun Registered Member
    Aug 28, 2002
    12
    Im currently building a blazer with an 8in susp lift, did a shackle reversal in back, add-leafs,homemade saddles, 8in superlift springs in front. have a th350, np203, 10bolt frt(4 now) 9.5in 14bolt rear(4 now) plan on switching to 14bolt ff somtime. I ve gotten as far as setting my driveline angles( my saddles are cut off rear end and not rewelded, (so turning rear end not a problem)cv shaft in the front.I plan to run this on the road, shrt drives, to work and back occasionaly. My problems are...opinions on a rear cv shaft? is it a deffinate must have? if so how do u set angles 4 a rear cv shaft? and do i set my angles differently if i plan to use some sort of traction bars? waht about lowering the t-case? any help would be greatly appreciated, feel free to email kevin_saun@hotmail.com thxs in advance. /forums/images/graemlins/dunno.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I think the CV shaft is a very good idea in the back. You want the pinion pointing straight at the output shaft of the transfer case.
  3. kevin_saun
    Aug 28, 2002
    12
    straight at it? I thought u leave the pinion a few degrees down from straight
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think what you meant is that you'll want the pinion 1 to 2 degrees below pointing directly at the DRIVESHAFT not transmission output.
  5. kevin_saun
    Aug 28, 2002
    12
