Driveshaft angles/operating u-joint angles??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Dec 26, 2001.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Hey guys,
    Did a search but couldn't find where I saw the info about d-shaft angles and how much is too much for a u-joint to handle? I have a vibration at higher speeds when I let off the gas that is really annoying me. I have a 6" lift, rear shackle flip (4") with 2.5" springs also, 14bff...anyways, got some time this weekend and measured the angles again. Here's what I got (I forgot my damn notes at home, but this is what I remember, if they are off, I will let you know):
    Driveshaft angle = 21 degrees
    T-case output = 6 degrees down
    pinion angle = 8 degrees up
    So, it looks as if the u-joints are within 2 degrees of each other, but is the operating angle (15 and 13 degrees respectively) too great? I could have sworn they were supposed to be much less than that, but thought I'd ask to make sure. Am thinking about flipping the rear shim around and seeing what happens to all the angles, and see if the vibe goes away. It is vibe free all the way up to speed, but upon getting off the gas it always vibrates on me, sounds horrible! Added info - I have the t-case spaced down an inch and the shims in back are 6 degrees...
    Thanks for any help...
  2. kpanza
    Dec 8, 2000
    1,579
    Anyone have any idea of what the operating angles need to be? By the way, I also have a Detroit in that 14bff (I have heard that with low gears and a Detroit these vibes seem to be more prevalent...)
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i am having the same prob with my shaft..i just put the 14 bolt in with the 465 so my agles are not quite as steep as yours would be with a auto...but i have them within about 2 deg. and it still makes noise when i let off doin anything above 60mph..so i also would like the answer to this one..my rear is a 14b FF 4:56 and detroit so we are set up almost the same except for the tranny
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  4. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I have the same set up with the same problem. Is it possible it is the Detroit?
    <font color=red>....But I thought that sound was normal....!</font color=red>
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i dont get what your measurements are in relation to?
    the pinion should be a few deg below so that when the axle wraps up under power it is in phase
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    I got a welded 14 with the SM 465...the driveshaft is a fixed yoke version and my pinion is within 2 degrees of pointing directly at the T-case. I have no vibes at all and I've had my truck well over 90 MPH several times. Quite honestly my driveline looks like it is set up for a CV shaft.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  7. michaelm
    Feb 2, 2001
    872
    relative to ground what is face of TC angle? of machined dif cover surface?
  8. Chaz88K5
    2,979
    Stockton/Lodi CA
    <blockquote><font class="small">In reply to:</font><hr>
    Rene
    <hr></blockquote>
    Thats what my pinion looked like befor i had the perches cut and rewelded for the 2nd time...thats when the noise was really bad....maybe there is no real answer to this question...just trial and error untill it works for you...ya think?
  9. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Mine sounds exactly like yours Rene as far as the pinion almost pointing right at the TC, except for mine is a 14SF w/detroit. No vibes whatsoever. I never bothered measuring any of my angles, I figured if it aint broke......[​IMG] No shims on mine but I do have the ORD 4" shackle flip and 2" Tuff Country rear springs. I've lowered the TC the standard amount too.
    Works for me.
    James
    jimmy79@shaw.ca
  10. Chaz88K5
    2,979
    Stockton/Lodi CA
    the t-case i had it lowered but i had problems with the front shaft binding up...so i had to put it back up to the frame.....it solved some of the rear shaft vibrations but not all....witht he t-case back up stock and the pinon down its about the same as i had it with just the t-case lowered and the pinon pointing right at the t-case....have i confused ya yet...haha
  11. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    My T-case is dropped about 1/2"...I made some custom spacers for it.
    Rene
  12. Chaz88K5
    2,979
    Stockton/Lodi CA
    i think i am goin to try dropin the t-case again tonight and see what happens....couldent hurt to try
  13. kpanza
    Dec 8, 2000
    1,579
    But does anyone know the acceptable operating angle for a 1350 u-joint? I have dropped two shafts in the past and do not wish to repeat that...I lube the joints about twice a month to try to keep them from going dry...I also carry a spare shaft, but both times the shaft fell off it cracked the tailshaft housing at the same time...I wish I was as lucky as Rene with his setup (cv style but with no cv!), my attempt at that produced hideous vibes...as has every other way I have tried so far, except the way it is now - I just was hoping to get rid of that vibe when you are "coasting" between on the gas and off the gas...I am starting to think that it is just a side effect of the Detroit's sloppiness...I also remember someone saying that slip yoke 208/241s are more prone to this "mystery vibe" situation...
  14. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Are you losing your shaft due to U-joints essploding? Or is it that the shaft is too short? I really think the slip yoke is part of the big vibe problem we all hear so much about...
    Rene
  15. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Keith I get that same vibe your talking about. I have the flip in the rear with stock springs and no shim and it vibes like crazy. And only at the higher speeds while "coasting". I'm beginning to think it's just the Detroit too. I haven't done anything to it but have read everyones posts and it seems that it varies from truck to truck.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Spicer's "recommended" maximum operating angle is 4 degrees, but we're all past that as soon as the lift kit goes in. [​IMG] Wayne just spent a lot of time getting the vibes out of his. Maybe he has some ideas for you.
  17. Chaz88K5
    2,979
    Stockton/Lodi CA
    well mine dose not have the slip yoke anymore and its still makin the noise..
  18. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Wayne tilted his pinion up so it was sorta like mine...and it worked for him *shrug*.
    Rene
  19. Chaz88K5
    2,979
    Stockton/Lodi CA
    shrug is right...i think its just one of thos things
  20. kpanza
    Dec 8, 2000
    1,579
    As long as the u-joints remain in one piece I guess I can put up with it, but I hate not being able to find the problem and get rid of it! [​IMG]
    4 degrees??? Damn, who runs theirs at only 4 degrees?? [​IMG]
