Driveshaft angles
Discussion in 'The Garage' started by MTBLAZER89, Aug 5, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Ok with a non CV shaft the pinion should point where? I thought it was directly at the output of the T-case (0* angle at the pinion yoke) I was told yesterday though the angles should be the same at each end /forums/images/graemlins/dunno.gif Please help me fix my vibrations /forums/images/graemlins/grin.gif
    edit: I'll try and get a picture of my angles tonight
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Nevermind I found it I think. same angles at each end for a non cv shaft right /forums/images/graemlins/waytogo.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    your pinion should only be pointing right at the t-case if you have a cv shaft and since you dont your pinion angle has to be parallel with the output on the t-case, example if the out put at the t-case is say 20*, the driveshaft is say 10* then the pinion should be 20* NOT 10* like it would be if you had a cv shaft.Let me know if you have any questions.
    -CHris
  4. 1989blazer
    1989blazer Registered Member
    Jan 7, 2004
    35
    Bay Area, CA
    Don't forget to ad a degree or two for axle wind-up
