driveshaft clearancing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Sep 2, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a 6" lift on my truck. The front driveshaft angularity is bad enough for it to bind.
    Now, driving less than about 20 mph it is no a big deal, I can't hear a knocking/clunking sound and I do keep it lubed up pretty well.
    Over 25 mph and it makes the death-coming-soon sound. Sustained, I'm sure it would spit the driveshaft.
    I don't have the $$$ for a new one ($160 from Denny's) plus I can't see buying a 1310 driveshaft when I really would eventually like a 1350 one (even more $$$.)
    So, I have heard about clearancing the CV. I've taken out the driveshaft and and see where it could use some clearancing, but what do I clearance it with? How much is too much?
    I have a standard electric drill, but where could a get an attachment small enough?
  2. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    iam not being a smartass but did you reshim the axle when you put the lift on tho help with the pinion ang?
    bigb4x4.coloradok5.com
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The front springs did not come with shims. The shimns go between the axle and the leaf springs? Doesn't that mess up camber or caster or something?
    So, no, I didn't shim anything. ...?
