Driveshaft Compatability
Discussion in 'The Garage' started by MTBLAZER89, Aug 21, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Quick question. I am looking to sell a spare driveshaft. It came from a 78 K20 with a 203 to D44. Which if any other T-cases will this bolt too? Also will it bolt to a 10b without a conversion joint? Thanks.
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    It will bolt to a 10 bolt without any problems, it will even bolt to a D60 without a conversion joint since GM used the same size u-joing in all front driveshafts 1/2-1 ton (but D60's put the Ujoint closer to the t-case than a D44/10 bolt so length is an issue). But the determining factor in that driveshaft is the combined length of the tranny and t-case so just post what tranny/tcase it came off of and the buyer will probably be limited to that same combo unless they have a 6" or higher lift and need a longer driveshaft.. So also list the length of the shaft while it is extended and retracted (from center of u-joint to center of u-joint/flange). Then finally does it have a flange or U-joint on the tcase end?
