driveshaft extension
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, Apr 11, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    on an 84 k-5, is driveshaft extension neccesary with a 4" lift up front, and a 5" lift in the rear? im droppin the t-case, hope thats all I need to do. Thanks
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Maybe but most likely it will not be REQUIRED.
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you should be ok up to a 6 inch lift in the fron with no front drive shaft mods at all...but if ya went to 6 in the front you may have a problem when flexed out...in the rear yo might get away without having to modify it but more than likly you will have to lengthin it a little in the rear
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Your front will work fine. My rear worked fine with a 4'' shackle flip and 1 1/2'' blocks after lowering the T-case.
