Driveshaft length on 6" lift, 84 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, Mar 31, 2001.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    Driveshaft length on 6\" lift, 84 k5
    Even though I'm not as new as I used to be(now that I'm a full fledged jouneyman), I still have some pretty new person type questions.
    I recently had a tranny leak fixed. One of the bolts holding the t case to the tranny had stripped out the hole. A local tranny shop put in some threaded inserts and fixed it right up. While the t case was out, I had them put in new driveshaft output seals front and rear. But, the rear seal still has a slow drip. You can look at the t case output and see a drop of fluid on the edge. I bought my truck with a 6" lift already installed(springs in front, blocks in rear). Someone once mentioned the driveshaft might be a too sharp an angle. Opinions? Could the slip yolk be stressing under the 6" lift? I plan on some light off roading and want to have this leak addressed before I do so. I see there is a rear slip yolk eliminator kit for hte 205's. Is there one for the 208" How much? I have yet to see one advertised. Think it would be a good idea?
    I'm retaining my rear 10 bolt as far as I can go. I'll be upgrading to a locker soon. I have BFG Mud Terrain 35's on as well.
    <P ID="edit"><FONT SIZE=-1>Edited by NewK5Guy on 03/31/01 08:40 AM (server time).</FONT></P>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Driveshaft length on 6\" lift, 84 k5
    No kits for the 208.... One thing you might have is a leak coming from the center of your D-shaft yoke. Jesse, from High Angle Drivelines, posted once about a hole of some sorts in the center of the yoke and they will leak over time... This may be your problem.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
