driveshaft length q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stevewix, Feb 17, 2005.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    i've got a cucv blazer with a d60 front, 14bff rear, th400/np208c. if i wanted to get rid of the 208 in favor of a 205, what is involved? can i use my old driveshafts?
  2. stevewix
    Dec 2, 2004
    83
    ttt, and maybe i should give more info. i want to put in a nv4500/205 combo, BUT if a sm465/205 combo uses the same length driveshafts i have now, that's what i'll do.
    thanks in advance.
  3. stevewix
    Dec 2, 2004
    83
  4. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    208 t-cases use a slip yoke @ the case. 205's use a fixed yoke. Some later model 205's did come with slips, but not as strong or common. Also I think a 208 is shorter than a 205, but I'm not sure.
    I can't comment on the ability to use a different tranny. But if they are different overall lengths, then you'll most likely need to change.
