Driveshaft Length
Discussion in 'The Garage' started by daleearnhardt01, Jul 7, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I know its been asked before but sometimes the search function pisses me off. Anyways who has run the stock slip yoke drive shaft with a 6" lift?
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm running about a 6" lift (4" rear with a zerorate), 3* shims and a dropped transfercase, Still running the factory line
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I have, whats your question?
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Just want to see if it will in fact work.. Seems like it will so Im happy.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The stock shaft usually works fine with the later model blazers when the t-case is dropped a little. I ran mine for a year or 2 and finally had a new custom shaft built because 1310 joints and seeing how far the slip yoke was slid out always kept me un easy when ever hooking to a trailer or offroad.
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeh basically the only reason Im worried is because my 6" lift and 1 ton swap is gonna happen only 2 weeks before I go back to school so I didnt want to have to worry about dealing with that while tryin to get ready for school. After I get settled in Ill order one up tho..Thanks Bobby
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Those weren't 1310s, they were Saginaw S44 joints. Either way a 1350 is a good upgrade, that's what I run as well. /forums/images/graemlins/thumb.gif
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    well since you are swapping in a 14bff than I will share more with you...I noticed that the 14BFF lifted the rear another .5-1" or so over the 10B because of the larger tube and since I had a 10B it looked like it pulled the shaft out just a little further because a 14BFF pinion doesn't sit any further than a 10B pinion. If you have a 12b then it will help you out because a 12B pinion doesn't sit forward as far as a 14B.
  9. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Now what about front shaft? Where do I get a spacer that Ive heard about?
