driveshaft length?
Discussion in 'The Garage' started by Bhintz, Mar 8, 2005.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I installed 56s springs in the rear and it pushed my rear axle back about 5-6 inches so now I need to length my driveshaft but instead of doing that I was thinking about just geeting one off a SWB truck, would this work or would it be to short or long? and I can measure my driveshaft now Im about 250miles away so does anybody know how long a stock k5 and a stock SWB K10 truck driveshafts are w/ the 208 tcase
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    how did it push your axle back ? 52 and 56 make axle sit in same exact place,
    you drilled center pin hole back further ??
    hmm
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    That's odd .... I just replaced my 52's with 56's in my Suburban and the axle is exactly where it was before ..... except now it's a 14bolt.
    If the springs are in backwards then that would move it back almost exactly like you describe.:wink1:
    If that is what you want the just take your driveshaft to a driveline shop and give them a measurment from the center of the u-joint on the pinion to the center of u-joint or mounting flange or tip of output shaft .... depending on what you have. They should be able to re-tube and balance for under $100 if all your old stuff is good.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I had my old rear driveshaft I'd measure it for you, but I gave it away. (The one from when I had a 700/208).
    My rear shaft with the 465/205 is about 52" long IIRC, I think the auto one was ~ 45" or so. Anyone with a stock K5 with a 700/208 or 241 that can tell me what a stock K5 shaft is? 38-40"?????
  5. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    The springs have off set pin centers so if you install them backwards it pushes the axle back 4" :D
  6. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    yep and fliped the echobit backwards
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yep you can use a SWB driveshaft and just shorten it. While you are at it have them weld on a 1350 yoke :)
