driveshaft length
Discussion in 'The Garage' started by johnathan, Sep 30, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'm going to be installing a shackle flip on 84 blazer,np208 14 bff.I'm going to order a cv driveshaft from Tom Wood's before I get the flip.My question is should I go with the same length as stock shaft or what?
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    You will be fine with the same length shaft.
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    another question, will I need extended brake lines with 4'' lift
  4. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    If you plan on doing any kind of offroading, then the answer is yes.
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    what are some good shocks to run?
  6. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Im gonna run bilstein shocks when that time comes (probably next week). Not sure what series, but most likely plain 5100s. Probably the best name for our buildups. I gotta figure out what length though...
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Technically you should do the flip first then take the measurement for the driveshaft and have it built. Stock length should work but is probably not going to be the optimum length for your setup.
    Harley
