driveshaft length?
Discussion in 'The Garage' started by Disciples Performance, Jun 23, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys when i get my 14 bolt FF into my K5 will i need to shorten my driveshaft and if so how much???
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Too many variables to be able to give you an answer. You will need a conversion U-joint though.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    This is true, but I do believe you will end up lengthening your drive shaft. The pinion nose on the 14 bolt is actually a little bit shorter than your 10 bolt (I assuming 10 bolt) This is so because the 14 bolts have a pinion assembly that bolts to the front of the case. A long time ago I took some measurements from my 10 and 14 bolt and the 14 ff turned out to be almost 1 inch shorter from yoke to center of axle tubes.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Actually the 14ff pinion nose is longer than a 10 bolt.
  5. goldwing2000
    goldwing2000 Guest
    When I did my swap (from a 12-bolt), I also rotated the pinion up and I ended up getting about 1.5" removed from the d-shaft.
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I never had a length issue after the swap.
  7. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    As you can see already, far too many variables too predict. BTW my d-shaft needed shortening, but that was because it came out of a long bed pickup.:D
  8. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    i had a 12 bolt in mine just put in the 14 bolt ff and have not changed a thing. of course i have not put in the 6 degree shims either.
  9. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i say it depends on a few things
    what tranny
    what lift
    did you move or change the rear spring length or position
    hummmmmm
    LUKE
  10. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I added an inch to the drive line after the swap
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am pretty sure when I measured the 10 bolt vs 14bff when I did my swap the 14bff pinion was about 1" longer then the 10 bolt.
    I didn't have to modify my driveshaft at all when I installed my 14bff. My combo is a stock driveshaft with 700R4/208 slipyoke setup. My tcase is shimmed down a little to help with vibs.
    Harley
