Driveshaft Length ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77fixer, Mar 13, 2002.
  1. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    When building a driveshaft are there enough splines in a stock shaft to accomodate a 6" lift from full compression to full droop. The reason I ask is that I'm getting ready to swap everything from trans to axles (from th350,203,12b,10b to th400,205,14bff,d60). This is my daily driver and I will only have 4 days to perform the swap. I'm trying to determine the length of the shafts I will need beforehand. Does anyone have this combo that could give me some input? I would like to have the shafts built to accomodate the lift even though I am stock now.
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    The only way I know of measuring for driveshafts is to do it once everything is in the truck. That way you get it exact and not just close enough. I think the measurement is from the center of the u-joint cap to the center of the other u-joint cap, but it has been a while since I read up on it. You could probably call a driveline shop and get all the info you need.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You need to measure them after you lift it. If they make them for a 6" lift and you are stock height they will bottom out.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Like they said the only way to do it is after the lift. Even if you find somebody with the same combo there is no garentee it will work on your truck.
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    4 days.....thats quite an endeavor for four days. i just had to put my two sense/cents in.....i have the difference in tranny sizes back on my comp at home, but the t-cas, and diffs i dont know. the length is just a simple geometric function, you'll just need the lengths first.
  6. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    Why does the lift matter as far as compression is concerned? If I have a 6" lift and bottom out the suspension isn't that the same as bottoming out the stock suspension. As for the lengths I guess I'll just have to get everything in place first. BTW, that's what the driveshaft shop told me also, but I thought I would try. Thanks for your input though.
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    lets say the driveline is 2" longer for a 6" lift, if you try to run your truck with that shaft in there it will bottom out in the tcase since it is longer then stock on a stock truck.
