driveshaft length
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89 Blazzer, Aug 13, 2000.
  1. 89 Blazzer
    89 Blazzer Registered Member
    Aug 9, 2000
    29
    I just installed a 4" lift on my 89. It looks as if the rear driveshaft may need lengthened. How can I tell for sure? How much of the slip yoke should be inside the transfer case at ride height and at full suspension travel? I see Denny's Driveshaft Service has a website and the prices looked ok (150$) and most of the 4x4 magazines reference them.
  2. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    When I had my four in lift I was getting some vibration and it looked as thought the driveshaft was a little short. Instead of just having it lengthened, I went ahead and bought one with the cv joint in it. This solved any vibrations I had plus lengthened it at the same time. Having the cv joint will also help with any binding you might get during articulation.
