Driveshaft lengthening
Discussion in 'The Garage' started by FL84K5, Aug 31, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Whats the going rate to have front and rear shafts lengthend for around 7 inched of lift? thanks
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i had to get my rear done at a machine shop and want to say it about $40.00.
  3. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Thats not too bad of a price. Did they also balance it for you?
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    do you think i would need that done for a 4? im guessing it might be just about right with it stock, but some rigs ya just never know....seems eveyrones is a lil different..
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    $40.00 was a hell of a deal. Here in Denver it is $65.00 for labor and $1.00 per inch of tube needed.
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Stalnakers Machine shop does shafts. They dont "balance" They true shafts. Theyve done it for me before it it was smoooth. Theyre doing my shafts when I do my axle swap.
  7. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    In my effort to dig up at least one old thread per week /forums/images/graemlins/grin.gif , I thought I would add the info from getting my driveshaft lengthened.
    First the setup, 73 Jimmy, 205, 12 bolt, shaft with 2 u-joints and a slip joint (not a CV), 4" rough country springs
    The old shaft measured 39.5" compressed and 43" extended. I measured the distance from case to axle and it was 43.5". So I had them extend it by 2.25". That would put the 43.5" at the dead middle of the slip joint. I didn't see a reason to have it offset from the middle unless I have to lower my case in which case the slip joint should compensate.
    It cost $120, but that included two new u-joints installed since my old ones were shot. Without those, it would have been just under $100.
    It looks great, I can't wait to get it under there (hopefully the weather will cooperate!!).
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    After I put in my 6" lift, I had new drive shafts made. All new everything. I paid around $200.00 per driiveshaft.
