Driveshaft Mods Required for 6" or 8" lift on a Suburban
Discussion in '1936-Present Suburban' started by IGOR, May 22, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Driveshaft Mods Required for 6\" or 8\" lift on a Suburban
    Just curious...
    Would any driveshaft mods be required on either a 6" or 8" lift for a 73-91 style Sub?
    Thanks...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Driveshaft Mods Required for 6\" or 8\" lift on a Suburban
    8" yes, 6" possibly, i'm running 5" front and 7" rear and my rear is fine (tapered blocks) my front has a slight vib from the angle of the shaft, but when I put the 3/4ton D44 under it, i'm going to put in a degree block to help.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I would think they would need lengthened, my 4" lift really gave the yoke/slip joint a good pull in the wrong direction.
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    8" = yes
    As far as 6", it all depends on what yer gonna do. If you'll never flex it, it won't need to be lengthened. If it only see's pavement (aka mall cruiser), then no it won't. However, If you actually like to hit some trails for fun, I'd strongly recommend it be lengthened. Finding out on the trail that it should've been lengthened is a bad time to find out. /forums/images/graemlins/grin.gif
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Did a 6" lift on the Burb and it did not need to be lengthened............however, I did not run it up a ramp and test the flex since I will be going nuts with this rig but as said above, depends on your use.
