driveshaft mounted e-brake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Triaged, Jun 5, 2001.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    With all the stuff all of you guys & gals have done there has to be someone who has done this.
    I want to put one in because it will work on all 4 wheels and I don't trust just puting it in park (I might also do a NV4500 conversion). I don't think it should be that hard to do on a fixed yoke np205. I'm thinking a Wilwood mechanical calaper, a plate steel disc, caliper mounting bracket, and cable mods. I did some searching and found they used to be on Jeeps, some motor homes have them, Highangle driveline is looking into making a kit.
    What do you think?
    '71 Blazer CST with alot of rust
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    When I installed my TSM kit on 10 bolt a few years ago they had some other options in a cataloq they sent me of kits that they had and some were kits for driveshaft brakes. What you are talking about is like the old HMMWV.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Does TSM have a web sight? Thanks for the quick Reply.
  4. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    I don't think so, but their phone # is 303-688-6882 or email atr TSM MFG@aol.com.
    The General
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Jesse at Highangle Driveline is working on one - don't know if it is production yet...
    <A target="_blank" HREF=http://www.highangledriveline.com/>http://www.highangledriveline.com/</A>
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    With a locker what will you do about the slack in the locker? Even with the brake set you could roll the truck back and forth probably 8".
    I thought I was wrong once,
    but I was mistaken
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Hum...I never thought about that. I could just go with a spool than (I think I would rather have a spool anyways). The only prob I could see with the slack is in a parking lot where it could roll into another car (my blazer rarely sees parking lots).
