driveshaft problems for 5" of lift and 1" more wheelbase??
Discussion in 'OffRoad Design' started by muddysub, Jun 3, 2002.
  1. muddysub
    Jun 23, 2001
    my garage, Henderson, NV
    driveshaft problems for 5\" of lift and 1\" more wheelbase??
    i'm looking into some offset zeros for the front to move my front end foreward 1". will i have a driveshaft problem? i was thinking about a spacer for the front driveshaft what do you think of these stephen? and do you make them?
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    Re: driveshaft problems for 5\" of lift and 1\" more wheelbase??
    You just have to check the amount of slip available to see if the shaft will stand the extra extension.
    I don't have a problem with a spacer for the driveshaft, it's an extra part and in general the more parts the worse off you are but there's no reason it wouldn't work in your case. Check the cost to re-tube the shaft first, it may be close to the same as a spacer.
