driveshaft problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jun 23, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    i just installed my 4 in lift, and neither the front nor rear drive shaft ft now. They need to be longer. Has this happed to anyone else with a 4 in? Is it possible i was sent a much bigger lift. It fit 35's with no problem what so ever
  2. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    Well i installed a 4" lift and I droped my trans so the rear shaft fits fine, it probably would have fit with out the drop just lots of angle and the front drive shaft is an inch too short al the way extended so i might need a new one. i got the 4" rough country lift, on my 82 6.2 Blazer
    Sergio
  3. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i have a 6" and have no problems until I get really flexxy
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  4. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I have A 82 with a 4 inch lift and and the transfer dropped and they both still fit.
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I did a 4" lift and my front drive shaft had to be lengthened... There is one or 2 others that had this problem as well, but I haven't heard of any with rear drive shaft problems.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I think it really is just bad luck and seems to be random. I am actually in the process of installing a Rough Country 4" lift. I have the front done and haven't dropped the TCase yet. But, when the suspension was fully extended, my driveshaft didn't have any problems. I will be putting on the rear springs and dropping the TCase tonight.
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
