driveshaft problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big75jimmy, Jun 26, 2001.
  1. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I just put an 8" Superlift on my 75 GMC Jimmy and the u-joint on the transfercase end of the rear driveshaft binds really bad. I was goingto lower the transfer case and add some angled shims to the rear to help solve this problem. I was also wondering about adding a CV joint to the rear shaft.Would that fix it? Any help would be greatfully appreciated.
  2. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    Well your no doubt gonna have a vibration, the driveshaft is so far out of its operating range. I would drop you transfer case an inch, not to much then you'll run into other problems, and most guys who have that much lift on a Blazer style need a CV on the rear, I will need one when I put in my doubler with a 6 inch as it'll be too short then,
    Never been stuck, just temporarily delayed.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    If you put a CV on your rear driveshaft, you will need to rotate your rear axle so the pinion points at the tcase.
    Dropping the tcase will help, but a Blazer has a pretty short rear driveshaft... I really don't have that problem with my long bed pickup.
    Someone on here has a blazer with an 8" susp. lift and should be able to help.
    -- Mike
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well 8" is a good time to look at a CV shaft.... Is the shaft long enough? That will cause problems... The guy I bought my lift kit from has 8" of suspension lift on his Blazer w/ stock style shafts... he used a 2" drop on the tcase... I can give you the number if you wanted to inquire about it... real nice guy at Ken's 4x4 here in MN.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    8" on a K5 is a very large suspension lift. In fact, even for a longbox pickup, that is a lot.
    Tim
