Driveshaft Qs?
Discussion in 'The Garage' started by southernspeed, Dec 28, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm just putting a 4" lift on my '91. (stock rear springs with shackle flip).
    Will my rear drive shaft be long enough or will my slip yoke drop out of my 241 on full droop?
    Anyone with 4" lift running stock d/shaft with no probs?
    Thanks.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    I have a 4" lift with stock shafts, but I do have the T-case dropped 1"
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That's a thought! Did you have any distributor clearance probs or driveline vibration after dropping the t/case?
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i used to have 4", no problems with it, and no t-case drop or anything.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That question has a different answer for almost every truck.
    No the slip yoke won't fall out.
    Vibrations.... try it and see. Some have em, some don't.
    Shaft length....should be fine. If you need a longer one, let me know. I had one made and only used it for 3 weeks. Then I went 1 ton, so it is just sitting.
  6. dave_90_blazer
    Jan 1, 2004
    688
    nope, no vibration issues, or dist. clearance issues(before I went LT1)
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    OK thanks guys, that was what I was hoping to hear!
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Pesky highjackers! Where's Bruce Willis when you need him!!:D :D
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
  10. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    just for your info in my 86 k10 shortbed w/ 6 inches in it the slip yolk was fine until you slammed on the brakes on pavement then it would fall out. but that was 6 inches w/ dropped t case
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    haha i didnt lengthen my front with 8" lift, splines showed some but it worked. oly problem was y-pipe clearance. wdidnt have any problem with 4"
  12. KTEX
    KTEX Registered Member
    Nov 8, 2005
    19
    wylie
    my 90k5 had a bad vibration at 40-55 mph after installing the 4 " lift.i shimed the rear avle 2 degrees and dropped the trans case half an inch,still had slight vibration.I called driveshaft solutions-they build double carden frt u-joint driveshaft-no problems at all after that
