Driveshaft question - Drivelineman?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, Aug 6, 2006.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    so, i finally got some time to put my junk back together..... i put in another 700r4, SYE on the 241, HAD 1350cv shaft w/ 1410 pinion, 1410 yoke, diy4x flip w/ 56's and 6" shackles, BWP 1.5" zero rates, and i have the axle moved to the rear 2.5" by installing the 56's backwards, and moving the axle back up 1.5" w/ the zero rates. and i got some bling bling brakelines from Xtreme Crawlers and those fancy greaseable bushings from ORD.
    here's my question..... i put the new HAD shaft in, i believe it was made correctly to the measurments that i was told to measure, but it has about 3/4" of inward travel before it bottoms out. is that normal? or should i worry about it bottoming out? IF it is a problem, then i can, (and would almost like to) move the axle back another 1/2". I will call Jesse if I don't get an answer here, just thought i'd get opinions here first. anyways here's the pics...
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I don't think that is enough for compression. Better wait for Jesse to reply or call him like you said.
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I only have about 1.5 inches showing in mine and thats plenty but that looks a little short
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    It should be set up with 2" of compression. I don't work for HAD anymore....but I did set up hundreds of shafts like that...all with 2" of compression.
  5. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i talked to Jessie the other day, and he said he likes to see minimum of 1.5"..... i'll move the axle back another half inch, if that don't do it, i'll try putting it at the full 4" to the rear. i'm actually glad it turned out this way, i could use some more wheelbase.
  6. fright98
    fright98 Registered Member
    Nov 21, 2005
    32
    south of Boston
    I just got the front and rear from HA and they are both long. the front looks just like your pic. I will call HA later today and see if he can make them a little shorter
