driveshaft question with 14bff swap?
Discussion in 'The Garage' started by MJB774X, Mar 4, 2003.
  1. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    tomorrow I'm going to install my 14bff,also I'm going to do a doit yourself shackle flip, I also made my own zero rates which will move the axle back 1" from the original location. My question is am I going to have to shorten my drive shaft do to the longer housing? will I have to put a different yoke with a different u-joint on the end? or will the 1/2 ton u-joint fit in the 14bff yoke? /forums/images/graemlins/usaflag.gif
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I assume you're going for 5-6in lift with zero's and flip so shaft will prob be OK.Longer pinion on 14B should equal extra length of lift.You prob can get a conversion joint to work,but,the small end of the joint will wear faster than normal.1330 to 1350 is #447{pretty sure},don't know what 1310 to 1350 is. /forums/images/graemlins/thumb.gif
  3. MJB774X
    Sep 26, 2002
    574
    SO CAL
    so the joints are a different size then?
  4. ZonkRat
    Jan 16, 2003
    1,003
    All the 14Bs I've seen run 1ton 1350 series joints.It's the same cross size as 1330 with larger dia. /forums/images/graemlins/thumb.gif
  5. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    yes they are different.you can get it at napa .
  6. MJB774X
    Sep 26, 2002
    574
    SO CAL
    so you can put the cups from the 1350 on the 1330 cross? keeping the 1330 cups on the driveshaft yoke and using the 1350 cups on the 14 bolt yoke? or do I have to get a different yoke welded on the driveshaft? I'm not to clear on what you meen
  7. ZonkRat
    Jan 16, 2003
    1,003
    Nope.The OD of the bearing surface is larger too.Have to run #447 conversion joint. /forums/images/graemlins/thumb.gif
  8. MJB774X
    Sep 26, 2002
    574
    SO CAL
    is that a napa part #?
  9. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Wes disproves this theory here . Look at the second post.
  10. ZonkRat
    Jan 16, 2003
    1,003
    The ones I use are Precison by Federal Mogul #447. /forums/images/graemlins/thumb.gifMy mistake on pinion length.I just know that mine worked OK with about the same setup.SWB truck may make a difference.Sorry. /forums/images/graemlins/thumb.gif
