driveshaft question
Discussion in 'The Garage' started by kutter79, Jan 2, 2006.
  1. kutter79
    kutter79 Registered Member
    May 17, 2005
    48
    st. charles MO
    i have an 84 k5 w/ 465/208 shackle flip and zero rate. has anyone tried using driveshaft from shortbed or longbed pickup. does it work well? mine still works but slip hangs out a little and it leaks fluid. thanks for the help. also if you have a driveshaft to sell let me know.
  2. fordtruggy
    fordtruggy Registered Member
    Dec 30, 2005
    55
    Red neck ville Rapid city SD
    I dunno but if you have to remake one get one that is too long.Its cheaper to shorten them than lengthen.
  3. kutter79
    May 17, 2005
    48
    st. charles MO
    ttp
    ttp...........................
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have a short box pickup driveshaft in mine. I think I had to take out ~7" but as mentioned above it's cheaper to shorten a shaft. If you use the conversion jont in the rear find a driveshaft from a 4spd truck then you wont need the conversion joint cause 4spd trucks got a 1350 joint on the axle end. BTW your T-case leaks because of the seal in the slip yoke. Mine leaks too and the shaft is the correct length. new seal helps for awhile, but it's just the nature od the slip yoke. That was you can tell everywhere you have parked:D :haha:
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what length do you need?
    ive got 2, both longer than stock
