Driveshaft Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, Jun 24, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    Im doin a 9" susp. lift in the rear and 8" in the front
    (just got the springs today /forums/images/icons/laugh.gif) As far as driveshafts, will all i need to do is get them lengthened? Or will I have to get a CV shaft for the rear? Also, I've been quoted $100 per shaft to get them lengthened. Is that a fair price. Thanks for the help.
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    If your T-case uses a slip yoke (I don't know what year your truck is) it will need a c/v shaft. As for the price of lengthening them, that is a whole lot cheaper than it is in my area.
  3. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    I have an 84 with a 305, 700r4, to an np 208 i believe, not sure though. And i dont think its slip yoke either.
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    If it is a 700/208 then it has a slip yoke.
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    What size tires you planning on running under that thing? My guess is you are running stock 10-bolt axles. I hope this is just a pretty truck if you plan to run a 305/700/208 combo with oversized tires and that much lift. Cause that is the weakest combo you could possibly put together.
  6. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    thanks for the info. Yep this is the pretty rig. The beater is soon to come.
