driveshaft removal help
Discussion in 'The Garage' started by muddybuddy, Jun 10, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i need to take my rear driveshaft off to lengthen it. so far i have the rear part disconnected from the axle. what do i have to do for the part that is connected to the transfer case? (its a np208) can i just pull the slip yoke out still connected to the driveshaft and take it to get lengthed like that?
    sorry if my question sounds stupid, but i dunno what to do??
    thanks for the help in advance
  2. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    yep, just pull it out. some atf might come out when you do. depending if your doing this in your driveway. :grin:
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    FIXED IT ---- :D
    all i can add is you will need to top off the 208 after you put in you longer drive shaft
    i think 2qts will come out of the 208 when you pull the yoke out get a oil pan under it
    good luck :D
