Driveshaft Rotor/brake system info needed
Discussion in 'The Garage' started by trukman1, Apr 23, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    I'm totally oblivious to how this is done. Any info would be greatly appreciated. Gary
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    parking brake? or pinion mounted a la rockwell conversions?
    I have seen a friends mud racer that has a ~1/4" plate welded to the rear yoke on the 205 and he runs a common chev caliper on it as his only braking.
    for parking High Angle uses their flange style output yoke as the mounting point for a laser cut rotor.
    I am thinking about looking to use the ujoint mounting straps as the attachment for a rotor as I am unsure I would want to weld to the yoke
    that what you had in mind?
    want some links to calipers?
  3. trukman1
    Mar 5, 2002
    129
    Ohio
    m j, I am thinking of rear disc brakes but not sure about the new things I'm hearing about T/C rotors, calipers, etc. I guess this is the same basic concept used on the military axles only attached to the T/C. Right now I'm trying to figure out a cost effective way to have rear discs and still have a reliable e-brake system too. From what I read, the caddy e-brake system isn't highly regarded by many as being adequate on large trucks. Any further info would be greatly appreciated. Thanks, Gary
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
