driveshaft ????'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by funkycold, Mar 7, 2004.
  1. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    driveshaft ????\'s
    I am finally finishing the install of the 12" lift and the 14FF install at the same time.
    I have a questions regarding the drivehshaft slider at the transfer case.
    Is it too far out in the picture below?
    If I were to get a new driveshaft, how does it get measured from u-joint to u-joint, and how far in or out show the yoke be when measuring for the new driveshaft?
    Thanks for the help.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: driveshaft ????\'s
    That looks a little far out but it could be ok, I don't know for sure. As for the measure, ask the driveshaft shop you get one from. They will tell you exactly how to measure it. Some shops measure from different places I have heard.
    Make sure when you measure it that you have the full weight of the truck on the suspension so it will be at ride height.
    Harley
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Looks like that shaft will have to be Extended.........
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    If that is a factory slip spline then its too short. I think on those they measure from the face of the output to the center of the ujoint cup on the pinion.
  5. Re: driveshaft ????\'s
    Yep, too short. You can supposedly operate with 60% of the slip yoke in the transfer case. I just had my driveshaft lengthened 2" because I had less than 50%.
  6. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    12" geeez....huge mofo
