Driveshaft shop in Seattle, WA
Discussion in 'Pacific Region' started by rcamacho, Apr 11, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Any recommendations on a local DS shop? I have a nice CV shaft for my 208/14BFF setup that needs a little re-work. The slip shaft was machined too much on the OD so the transfer case leaks a lot. Yep, it's the yoke, not the seal. I have a std. DS which works just fine.
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I have only used them for little stuff but percision driveline in Kirkland has always done OK. Usually use six states or Tom Woods for the big stuff. But most likely will look at HAD for the next big project. All of which are not local but if your not in a rush would be my reccomendations.
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    several friends of mine have had great luck at aukeem drivelines in auburn...
