driveshaft spacer for t-case?
Discussion in 'The Garage' started by muddybuddy, Sep 9, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what are the general opinion on these?
    thanks,
    james
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have used the Superlift spacers in the past without problems! May use one on this 90 I just got or make a square shaft.
  3. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Are you talking about the spacer the goes between the driveshaft and t-case? if so...I also have the superlift spacer on the front. I haven't run into any problems due to having it and it really helped getting the shaft away from the cross member.
