Driveshaft Spacer
Discussion in 'The Garage' started by Smitty, Apr 27, 2004.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I put a 4" lift in my truck and need to do something about my front driveshaft. I've heard about 1" spacers for the front shafts but have never actually seen one. Are these a good solution for making the front shaft longer? Any down side? Also, where would I get one?
  2. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Got mine from Rocky Mountain Suspension. It is 1" thick. I am running 8" sup. and have had no trouble out of mine. I really don't think that you need one with only 4" sup. but if you are binding you can always take your shaft out and /forums/images/graemlins/grind.gif the ears off.
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Had to do this to mine with a 6". Not that hard. Hardest part was pulling the drive shaft. I ground a little more than I needed, I think, but works great now.
  4. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I'm not having a problem with any binding (but then I haven't driven it yet). I'm looking at the splines in the slip-joint and they are right at the edge of the seal. Just figure it would be better to have the splines closer to the center of the slip-joint.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You're going to need to grind. Probably not as bad as I did with the 4 speed when I had a stock shaft, but even when I had a 700R4, my CV would click from binding.
    Binding has the capability to be very destructive to your u joints very quickly, so I would make sure you grind that CV when you have it out again.
    Getting a stock shaft from a 700R4/NP 208 truck might be an idea too--they're slightly longer because the transmission itself is longer and that might give you the added length that you need.
  6. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Forgot to add that this is for a 203 to D44. Will the shaft from a 208 work on a 203?
