driveshaft spline lenght
Discussion in 'The Garage' started by DERBINATOR, Apr 1, 2005.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I just installed a front dana 60 in a 76 chevy. I have a 4" lift and a 203 t-case. I put the driveshaft back on and I only have maybe 3/4" of travel before it is fully compressed. This doesn't seem like much or is it OK. I suppose it is somewhat vehicle specific but is there a number to shoot for?
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well this is what you can do....
    take the front shaft out... go flex the most the truck will.. and try and put the shaft in.... thus showing if it is ok....
    if it does bottom out.. you dont want the driveshaft going through your t-case :crazy:
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    3/4" is not enough
    You will more than likely bottom out the shaft, and if that happens you will either break the case or the adapter (neither are cheap or fun to fix). Find a shorter shaft that will work or get that one shortened. The good thing is that it's cheaper to get a shaft circumcized than to add length to it :blush:
  4. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    So if I shorten it, how much should I go. At ride hieght do you want to be in the middle of the spline travel or ????
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If you don't mind the extra height, you could use a set of zero rates to move the axle forward. This would give you more clearance and solve your length problem. Would kinda be tackling it backasswards but if it works it works.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Just run Rough Country springs :grin:
    Measure from the top of the spring packs to the bumpstops. That is how much uptravel you might get if you jump the truck or something. Then simple high school geometry will let you figure out how short the shaft could get.
    As a general rule of thumb, yes, you want to be in the middle of travel at static ride height, but you might have more droop than stuff or vice versa.
