Driveshaft too short w/14bff swap?
Discussion in 'The Garage' started by gone huntin, Apr 22, 2005.
  1. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I installed my 14bff today expecting it to compensate for the 1" the 4" lift caused the driveshaft to pull out of the transfer case. Well, wrong, the yoke is now 2" out of the transfer case over what it was stock. Why did this happen? I still have about 4" still in the housing (241) I don't wheel this 'burb, but I do tow with it, should I have a new shaft made?
  2. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    Well, I was wrong,there is only 2 1/2" in the transfer case now. I just hate to spend $200 on a driveshaft.
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Why don't you just have it lengthen or buy mine. I have the rear shaft out of my 90 burb when it had 8" lift. You would probably need to shorten the driveshaft. It was connected to a 465/241 and 14ff. Shipping would probably kill the deal unless you want to pick it up. I sometimes go to Gulfport so that might be 1/2 way. PM me if you are interested.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I didn't get mine lengthened, i wheel mine all the time, flex it out pretty good as well, never had an issue with the driveshaft coming out.
    to add: it's the same setup you have, mine's an '89
