driveshaft U-joint ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Jan 26, 2005.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I have a 1 ton 14 bolt FF in the rear of my K5, I moved the perches. I need to the part # of the ujoint I need to make my stock rear driveshaft work.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    DABONNNNTTTYUNT !
  3. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Well helloooooooo "Mr. Copy n Paste" button..thats a good chart to have!...:D:D
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yep, that chart is great........unless you are going from a rear 10-bolt to a 14-bolt ;)
    For that conversion, you need the S44 to 1350 conversion joint, try either 2-1153 (neapco) or 447 (Napa)
