driveshaft u-joint
Discussion in 'The Garage' started by suntadz, Apr 19, 2007.
  1. suntadz
    suntadz 1/2 ton status
    May 15, 2005
    187
    bay area, ca
    I was going to swap in my 14ff this weekend and was just wondering about the ujoint. I got the conversion one so the yoke part with the straps no problem but how do i get the other end out of the driveshaft? Hit one end out till i can pull the cap? Or should i pull out the driveshaft and take it somewhere to press it out? and if i do take out the shaft is there anything i have to do? or just pull it out and push it back?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you haven't done u-joints before you should take it somewhere and have it done or at least have someone show you the proper way to take it apart. Yes, you only need to pull the shaft out then once the u-joint is changed just slide it back in and bolt it up.
    Where in the bay area are you? I'm in fremont and do this for a living. If you're not too far from me then i'd say bring it to me and i'll show you how it's done.
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    Hijack on- Just curious, where do you work? I have some friends in the area, and they were asking me if I knew any shops out there.
    Hijack off
  4. suntadz
    May 15, 2005
    187
    bay area, ca
    Sweet. thanks for the offer. I live in walnut creek so i think it might be a bit far since i working out of my driveway. thanks for the tip.
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The name on the building is Total Auto Parts. I own the machine shop in the back of the store. My shop name is Fremont Auto Parts Dist., Inc. Commonly refered to as Fremont Machine.
