driveshaft vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1989blazer, Jun 23, 2004.
  1. 1989blazer
    1989blazer Registered Member
    Jan 7, 2004
    35
    Bay Area, CA
    My driveshaft is still vibrating a bit, contrary to my post a few months ago. Dang. I checked the angles between the driveshaft, transfer and axle and they're 9 and 12 degrees respectively. My question: at these angles do I need to go to a double carden shaft? I'm wondering if the axle is over-corrected and needs a 1 degree shim. I've been reading drivesaft sites and they seem to think a 1.5 to 2 degree correction is what's needed. I've got Rough Country springs in the rear, needless to say - stiff as hell. Anyone else solved a similar problem. Anyone got a 2" - 4" lift with standard drive shaft and no vibration? Anyone solved the problem by replacing old, worn shock absorbers?
  2. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    1980 K5 4" lift stock rear drive shaft. No vibration. /forums/images/graemlins/dunno.gif
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Is your transfer case crossmember lowered?
  4. 1989blazer
    Jan 7, 2004
    35
    Bay Area, CA
    cross member is lowered. I'm wondering if having different weight u-joints would make a difference.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    you can take two of the same rigs side by side one will shake and the other will not- but you need a c/v and proper pinion angle 2 degree's working (actual angle) and it will be happy again-Jess
  6. 1989blazer
    Jan 7, 2004
    35
    Bay Area, CA
    Yep, that's what I'm thinking. 9 degrees means a significantly lower u-joint life as well.
