Driveshaft with CV joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thedrip, Nov 5, 2004.
  1. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I know its a little 'light' for the center of gravity forum, but the people in here are the most likely to know.
    In a CV joint as part of a driveshaft, I found a connector (ball & socket) between the two parts of the driveshaft. Its inside of the CV assembly, and seems to equalize the angle of the two ujoints. Is this ball & socket nessecary for the proper operation of the CV joint.
    I'm looking into building a driveshaft with a CV, so I need to know if I need to integrate the yokes with this ball & socket cast into them, or if I can just use standard yokes on each end of the CV, and the "coupler", and have it all work right.
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The ball and socket are what makes a CV work the way it does. Without it you would just have a triple u-joint driveshaft and that would whip aroun like crazy.
  3. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Thats what I thought when I took one apart last night, first time I've torn a CV down. Thanks for verifying that for me.
